[FOSS-GPS] I always get "no double-differenced residual" message with RTKLIB
Jochen
jochen.brunssen at web.de
Tue Oct 16 03:05:31 PDT 2012
Here is the data of the test over 10 Minutes:
https://www.dropbox.com/s/zjuoeqsw45f058f/rtklib.zip
The .txt files are the raw data streams with the ubx / rtcm data and i also
added the converted .pos / .nav files.
And what i didn't write is that i use the windows version. I have used the
linux console version earlier and i got the same results.
I also took a screenshot on how the window looks during the test, which i
forgot to add in the last message:
https://www.dropbox.com/s/pkjdekltsqhe725/rtknav.png
I access the base station computer via ssh on a linux laptop, which sends
the data via UDP to a specified IP. Because RTKLIB only supports TCP, I use
netcat to forward that data via TCP to my windows Laptop which i then take
outside with the Rover GPS attached to it. But all that works with no
problems.
And i have never heard of valgrind, but i looked it up and should be able to
test with it. I only interpreted the debug data i had together with the
source-code, so the problem might be somewhere else, but i am pretty sure
that it's there.
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/I-always-get-no-double-differenced-residual-message-with-RTKLIB-tp7572550p7572552.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
