[FOSS-GPS] Decoding UBX data
Sandra 46a sandra46a at gmail.com
Thu Apr 4 16:35:35 PDT 2013
I need help, I have LEA 6T and not decoded RTKLIB.
Regards
Sandra.
On Thu, Mar 14, 2013 at 5:39 PM, Tomoji TAKASU <ttaka at yk.rim.or.jp> wrote:
> Dear Par,
> Thanks for pointing out a problem.
>  I managed to get a version of that code running, but
>> I had to change one file of rtklib to make that happen.
>> The change needed was that I commented out the
>> free_raw on line 300 of rcwraw.c. The free_raw calls
>> free() on the members of the struct. Then the struct
>> members are again accessed which causes a
>> segmentation fault on my platform.
> Or you can also initialize the raw struct in advance
> (without modification of RTKLIB).
> raw_t raw;
> raw_t raw={0};
> regards,
> Tomoji TAKASU
> From: "Degerman Pär" <par.degerman at scania.com>
> Sent: Thursday, March 14, 2013 4:50 PM
> To: "Open Source GPS-related discussion and support" <
> foss-gps at lists.osgeo.org>
> Subject: Re: [FOSS-GPS] Decoding UBX data
>  Dear Tomoji,
>>  Like the following codes.
>> I managed to get a version of that code running, but I had to change one
>> file of rtklib to make that happen. The change needed was that I commented
>> out the free_raw on line 300 of rcwraw.c. The free_raw calls free() on the
>> members of the struct. Then the struct members are again accessed which
>> causes a segmentation fault on my platform.
>> I'm using visual studio 2008 32 bit on a 64 bit platform and compiling in
>> debug mode. I'm not sure if I have introduced a memory leak making this
>> change or any other errors, but for my current use case this solution seems
>> to work.
>> Best regards
>> - Pär
>> ______________________________**_________________
>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>> Visit http://lists.osgeo.org/**mailman/listinfo/foss-gps<http://lists.osgeo.org/mailman/listinfo/foss-gps>to manage your subscription
>> For more information, check http://wiki.osgeo.org/wiki/**FOSS-GPS<http://wiki.osgeo.org/wiki/FOSS-GPS>
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20130404/398fc995/attachment.html>
More information about the FOSS-GPS mailing list
