[FOSS-GPS] Decoding UBX data
Nick Østergaard
oe.nick at gmail.com
Fri Apr 5 00:04:10 PDT 2013
No one can help you if you havent read any documentation or told us what
you have done.
On 05-04-2013 01:35, Sandra 46a wrote:
> I need help, I have LEA 6T and not decoded RTKLIB.
> Regards
> Sandra.
> On Thu, Mar 14, 2013 at 5:39 PM, Tomoji TAKASU <ttaka at yk.rim.or.jp
> <mailto:ttaka at yk.rim.or.jp>> wrote:
> Dear Par,
> Thanks for pointing out a problem.
> I managed to get a version of that code running, but
> I had to change one file of rtklib to make that happen.
> The change needed was that I commented out the
> free_raw on line 300 of rcwraw.c. The free_raw calls
> free() on the members of the struct. Then the struct
> members are again accessed which causes a
> segmentation fault on my platform.
> Or you can also initialize the raw struct in advance
> (without modification of RTKLIB).
> raw_t raw;
> raw_t raw={0};
> regards,
> Tomoji TAKASU
> From: "Degerman Pär" <par.degerman at scania.com
> <mailto:par.degerman at scania.com>>
> Sent: Thursday, March 14, 2013 4:50 PM
> To: "Open Source GPS-related discussion and support"
> <foss-gps at lists.osgeo.org <mailto:foss-gps at lists.osgeo.org>>
> Subject: Re: [FOSS-GPS] Decoding UBX data
> Dear Tomoji,
> Like the following codes.
> I managed to get a version of that code running, but I had to
> change one file of rtklib to make that happen. The change
> needed was that I commented out the free_raw on line 300 of
> rcwraw.c. The free_raw calls free() on the members of the
> struct. Then the struct members are again accessed which
> causes a segmentation fault on my platform.
> I'm using visual studio 2008 32 bit on a 64 bit platform and
> compiling in debug mode. I'm not sure if I have introduced a
> memory leak making this change or any other errors, but for my
> current use case this solution seems to work.
> Best regards
> - Pär
> This message is sent to you from FOSS-GPS at lists.osgeo.org
> <mailto:FOSS-GPS at lists.osgeo.org> mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to
> manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage
> your subscription
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
More information about the FOSS-GPS
