[FOSS-GPS] Decoding UBX data
Sandra 46a
sandra46a at gmail.com
Fri Apr 5 06:00:30 PDT 2013
Thanks.
I read now, sorry for my bad English. Is dificult for my, my language is
Spanish, I try translate a put my problem.
Regards.
On Fri, Apr 5, 2013 at 2:04 AM, Nick Østergaard <oe.nick at gmail.com> wrote:
> No one can help you if you havent read any documentation or told us what
> you have done.
> On 05-04-2013 01:35, Sandra 46a wrote:
> > I need help, I have LEA 6T and not decoded RTKLIB.
> > Regards
> > Sandra.
> > On Thu, Mar 14, 2013 at 5:39 PM, Tomoji TAKASU <ttaka at yk.rim.or.jp
> > <mailto:ttaka at yk.rim.or.jp>> wrote:
> > Dear Par,
> > Thanks for pointing out a problem.
> > I managed to get a version of that code running, but
> > I had to change one file of rtklib to make that happen.
> > The change needed was that I commented out the
> > free_raw on line 300 of rcwraw.c. The free_raw calls
> > free() on the members of the struct. Then the struct
> > members are again accessed which causes a
> > segmentation fault on my platform.
> > Or you can also initialize the raw struct in advance
> > (without modification of RTKLIB).
> > raw_t raw;
> > raw_t raw={0};
> > regards,
> > Tomoji TAKASU
> > From: "Degerman Pär" <par.degerman at scania.com
> > <mailto:par.degerman at scania.com>>
> > Sent: Thursday, March 14, 2013 4:50 PM
> > To: "Open Source GPS-related discussion and support"
> > <foss-gps at lists.osgeo.org <mailto:foss-gps at lists.osgeo.org>>
> > Subject: Re: [FOSS-GPS] Decoding UBX data
> > Dear Tomoji,
> > Like the following codes.
> > I managed to get a version of that code running, but I had to
> > change one file of rtklib to make that happen. The change
> > needed was that I commented out the free_raw on line 300 of
> > rcwraw.c. The free_raw calls free() on the members of the
> > struct. Then the struct members are again accessed which
> > causes a segmentation fault on my platform.
> > I'm using visual studio 2008 32 bit on a 64 bit platform and
> > compiling in debug mode. I'm not sure if I have introduced a
> > memory leak making this change or any other errors, but for my
> > current use case this solution seems to work.
> > Best regards
> > - Pär
> > This message is sent to you from FOSS-GPS at lists.osgeo.org
> > <mailto:FOSS-GPS at lists.osgeo.org> mailing list.
> > Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to
> > manage your subscription
> > For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
> > Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage
> > your subscription
> > This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> > Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> subscription
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20130405/b599449f/attachment.html>
More information about the FOSS-GPS
