[FOSS-GPS] PPP with RTKLib: RINEX O- and N- files?
Felipe G. Nievinski
fgnievinski at gmail.com
Sun Dec 22 15:53:41 PST 2013
If that doesn't resolve the discrepancy,
try discarding L2 observations as well.
There might be differences in the way
each implementation treats iono delay.
On Sun, Dec 22, 2013 at 9:52 PM, Felipe G. Nievinski
<fgnievinski at gmail.com>wrote:
> You have a mixed-type RINEX.
> I'm not sure how each PPP implementation
> treats SBAS, Glonass, etc.
> So I'd discard non-GPS observations,
> using RINEX.
> On Sun, Dec 22, 2013 at 6:54 PM, Anders Wallin <
> anders.e.e.wallin at gmail.com> wrote:
>> I posted the PPP solutions I got so far on my blog:
>> http://www.anderswallin.net/2013/12/comparing-gps-ppp-solutions/
>> If anyone knows how to reproduce the CSRS-PPP results with either gLAB or
>> RTKLib, let me know. I also posted my RINEX data-file if anyone wants to
>> try it.
>> The gLAB solution is already very close to the CSRS-PPP solution, but by
>> default gLAB produces data at 300s intervals (not 30s as CSRS-PPP) so I
>> haven't directly compared the time-series yet.
>> The RTKLib solution is off by ~4ns which is alarmingly much - although I
>> tried to feed RTKLib with the same input as gLAB, and tweak a number of
>> settings - but the 4 ns offset was always there :(
>> I could not get the other online PPP services to work:
>> AUSPOS works but I do not get a time-series of position/clock-offset as
>> output
>> OPUS works but I do not get a time-series of position/clock-offset as
>> output
>> GAPS and magicGNSS rejected my RINEX file and gave an error message.
>> Anders
>> On Sat, Dec 21, 2013 at 11:47 PM, Felipe G. Nievinski <
>> fgnievinski at gmail.com> wrote:
>>> Might want to try http://gaps.gge.unb.ca/
>>> And the multi-solution comparison centre:
>>> http://gge.unb.ca/Resources/PPP/Purpose.html
>>> Another comparison:
>>> http://gpsworld.com/a-comparison-of-free-gps-online-post-processing-services/
>>> On Sat, Dec 21, 2013 at 1:51 PM, Anders Wallin <
>>>> Thanks for the tip!
>>>> By extracting the receiver clock bias from the status-file, and playing
>>>> around with the RTKPOST settings I now get better results:
>>>> http://imagebin.org/283266
>>>> There's still a 4 ns offset between the CSRS and RTKLib solutions - I
>>>> don't know where it comes from??
>>>> ESA gLAB arrives at the same result as CSRS, so maybe I will look
>>>> closely at the gLAB settings next.
>>>> Thanks for your help - I will try to write a blog post about my
>>>> findings if/when I get at least three methods to agree on the results
>>>> (CSRS, gLAB, and RTKLIB)
>>>> Anders
>>>> On Sat, Dec 21, 2013 at 12:07 AM, Felipe G. Nievinski <
>>>>> I don't think you should use the time tag in the .pos file.
>>>>> I'd use instead the CLK records in the .stat file.
>>>>> See Appendix B.3 in the docs, "Solution Status File":
>>>>> *Receiver Clock‐bias States*
>>>>> *Estimated receiver clock bias parameters. The format of a record is
>>>>> as follows.*
>>>>> *$CLK,week,tow,stat,rcv,clk1,clk2,clk3,clk4*
>>>>> *week/tow : gps week no/time of week (s)*
>>>>> *stat : solution status*
>>>>> *rcv : receiver (1:rover,2:base station)*
>>>>> *clk1 : receiver clock bias GPS (ns)*
>>>>> *clk2 : receiver clock bias GLONASS (ns)*
>>>>> *clk3 : reserved*
>>>>> *clk4 : reserved*
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20131222/6c913951/attachment-0001.html>
More information about the FOSS-GPS
