[FOSS-GPS] PPP with RTKLib: RINEX O- and N- files?
Felipe G. Nievinski fgnievinski at gmail.com
Sun Dec 22 15:52:23 PST 2013
You have a mixed-type RINEX.
I'm not sure how each PPP implementation
treats SBAS, Glonass, etc.
So I'd discard non-GPS observations,
using RINEX.
On Sun, Dec 22, 2013 at 6:54 PM, Anders Wallin
<anders.e.e.wallin at gmail.com>wrote:
> I posted the PPP solutions I got so far on my blog:
> http://www.anderswallin.net/2013/12/comparing-gps-ppp-solutions/
> If anyone knows how to reproduce the CSRS-PPP results with either gLAB or
> RTKLib, let me know. I also posted my RINEX data-file if anyone wants to
> try it.
> The gLAB solution is already very close to the CSRS-PPP solution, but by
> default gLAB produces data at 300s intervals (not 30s as CSRS-PPP) so I
> haven't directly compared the time-series yet.
> The RTKLib solution is off by ~4ns which is alarmingly much - although I
> tried to feed RTKLib with the same input as gLAB, and tweak a number of
> settings - but the 4 ns offset was always there :(
> I could not get the other online PPP services to work:
> AUSPOS works but I do not get a time-series of position/clock-offset as
> output
> OPUS works but I do not get a time-series of position/clock-offset as
> output
> GAPS and magicGNSS rejected my RINEX file and gave an error message.
> Anders
> On Sat, Dec 21, 2013 at 11:47 PM, Felipe G. Nievinski <
> fgnievinski at gmail.com> wrote:
>> Might want to try http://gaps.gge.unb.ca/
>> And the multi-solution comparison centre:
>> http://gge.unb.ca/Resources/PPP/Purpose.html
>> Another comparison:
>> http://gpsworld.com/a-comparison-of-free-gps-online-post-processing-services/
>> On Sat, Dec 21, 2013 at 1:51 PM, Anders Wallin <
>> anders.e.e.wallin at gmail.com> wrote:
>>> Thanks for the tip!
>>> By extracting the receiver clock bias from the status-file, and playing
>>> around with the RTKPOST settings I now get better results:
>>> http://imagebin.org/283266
>>> There's still a 4 ns offset between the CSRS and RTKLib solutions - I
>>> don't know where it comes from??
>>> ESA gLAB arrives at the same result as CSRS, so maybe I will look
>>> closely at the gLAB settings next.
>>> Thanks for your help - I will try to write a blog post about my findings
>>> if/when I get at least three methods to agree on the results (CSRS, gLAB,
>>> and RTKLIB)
>>> Anders
>>> On Sat, Dec 21, 2013 at 12:07 AM, Felipe G. Nievinski <
>>>> I don't think you should use the time tag in the .pos file.
>>>> I'd use instead the CLK records in the .stat file.
>>>> See Appendix B.3 in the docs, "Solution Status File":
>>>> *Receiver Clock‐bias States*
>>>> *Estimated receiver clock bias parameters. The format of a record is as
>>>> follows.*
>>>> *$CLK,week,tow,stat,rcv,clk1,clk2,clk3,clk4*
>>>> *week/tow : gps week no/time of week (s)*
>>>> *stat : solution status*
>>>> *rcv : receiver (1:rover,2:base station)*
>>>> *clk1 : receiver clock bias GPS (ns)*
>>>> *clk2 : receiver clock bias GLONASS (ns)*
>>>> *clk3 : reserved*
>>>> *clk4 : reserved*
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20131222/e423d88c/attachment.html>
More information about the FOSS-GPS mailing list
