[FOSS-GPS] RTKLIB raw data
trentonisla
trentonastleyisla-smu at yahoo.com
Mon Dec 30 00:26:58 PST 2013
HI,
I am using 2 Ublox receivers for my setup, do i need to enable the NMEA+UBX
output or can i only use UBX output? So that lesser data will be transmitted
by the rf link. is it possible?
and what is the minimum bandwidth that i can use to transmit basestation
data?
Thank you for your ideas in advance.
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLIB-raw-data-tp7572740p7572781.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
