[FOSS-GPS] RTKLIB raw data
julio menezes yjmenezes at yahoo.com.br
Mon Dec 30 01:48:49 PST 2013
Hi Trenton,
you just need UBX, nmea is useless for rtklib.
i think, a 19kbps link is ok for 1Hz data rate, there are some time lapse between ubx packets 57kbps.
[]s
julio
Em Segunda-feira, 30 de Dezembro de 2013 6:26, trentonisla <trentonastleyisla-smu at yahoo.com> escreveu:
HI,
I am using 2 Ublox receivers for my setup, do i need to enable the NMEA+UBX
output or can i only use UBX output? So that lesser data will be transmitted
by the rf link. is it possible?
and what is the minimum bandwidth that i can use to transmit basestation
data?
Thank you for your ideas in advance.
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLIB-raw-data-tp7572740p7572781.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20131230/0812c73b/attachment.html>
More information about the FOSS-GPS mailing list
