[FOSS-GPS] make NTRIP with RTKLIB
mrt oddpost at ya.ru
Tue Feb 26 06:52:10 PST 2013
Sorry for the basic question regarding RTKLIB. I am trying to understand the
basic logic, so please don't judge too harsh :)
I would like to know whether this logical design could work using RTKLIB and
2  Skytraq S1315F receivers.
I am planning to use one Skytraq S1315F as a base station, that streams
corrections over the Internet (NTRIP server).
And second Skytraq S1315F as a rover that gets corrections (NTRIP client).
So I would like moving rover has corrected and more accurate results.
Does this schema will work, or I miss something in the basic concept? I am
getting confused because of the settings in rtknavi, especially with NTRIP
server output. Could you please let me know where I am setting it wrong:
1. Base station:
Skytraq S1315F <via serial port> ---- Laptop running RTKLIB
*Input*:
<http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/file/n7572635/bs.jpeg>
*Output*:
<http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/file/n7572635/bs2.jpeg>
I have some doubts whether this will work. I believe that for NTRIP output
should be in RTCM, however RTCM is not available as output.
*Options*:
a) what positioning mode should be set up? static, fixed or kinematic?
2. Rover:
<http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/file/n7572635/rover.jpeg>
I would very appreciate your comments.
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/make-NTRIP-with-RTKLIB-tp7572635.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS mailing list
