[FOSS-GPS] UCenter enable RXM-RAW packets
Michele Bavaro mic.bavaro at yahoo.co.uk
Thu Feb 28 23:20:19 PST 2013
Well I did not know of a RAM hack, assuming that the antaris4 trick does
not work on LEA6H.
The modification I have seen is a flash update, so sticks after a power
cycle.
On 01/03/2013 08:16, Timo Juhani Lindfors wrote:
> Michele Bavaro <mic.bavaro at yahoo.co.uk> writes:
>> Of course: LEA-6H does not officially support RXM-RAW.
>> You need to crack its FW to enable it, but that invalidates the
>> warranty.
> Since you only modify RAM the changes only persist until you reset the
> chip.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
