[FOSS-GPS] Decoding UBX data
Tomoji TAKASU
ttaka at yk.rim.or.jp
Tue Mar 12 07:09:30 PDT 2013
Dear Par,
> Can anyone provide me with a working code example
> on how to decode the data for this setup?
Like the following codes.
observation or navigation data are saved in the buffer
in raw data struct if input_raw() returns 1 or 2.
raw_t raw;
unsigned char buff[SIZ_BUFF];
int i,len;
init_raw(&raw);
while ((len=read(fd,buff,sizeof(buff)))>=0) {
for (i=0;i<len;i++) {
switch (input_raw(&raw,STRFMT_UBX,buff[i])) {
case 1: your_proc_obs(&raw); break;
case 2: your_proc_nav(&raw); break;
free_raw(&raw);
regards,
Tomoji TAKASU
Sent: Tuesday, March 12, 2013 10:29 PM
To: <foss-gps at lists.osgeo.org>
Subject: [FOSS-GPS] Decoding UBX data
> Hi,
> I have a ublox 5t receiver and I would like to decode the pseudoranges and
> Doppler shift that is included in the ubx output. I checked briefly
> through the rtklib source, and realize that everything is in there, but
> unfortunately a bit poorly documented.
> The situation I have is that I'm using rtklibs strsvr to read the data
> from the receiver or a log file, this is then published using the TCP
> server output and my application uses another TCP socket to read the data.
> Now I'm trying to decode the data using the input_raw functions, but I'm
> apparently using them wrong since I get segmentation faults.
> Can anyone provide me with a working code example on how to decode the
> Best regards from Sweden
> Pär Degerman
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS
