[FOSS-GPS] RTKlib begginer's question
oddpost
oddpost at ya.ru
Tue Mar 12 23:31:18 PDT 2013
Thanks. I was trying to enable ublox raw data from the gps chip, but got stuck at some point.
1. cat /dev/ttySAC1 gives NMEA without problems
$GPTXT,01,01,02,u-blox ag - www.u-blox.com*50
$GPTXT,01,01,02,ANTARIS ATR062x HW 80040001*26
$GPTXT,01,01,02,ROM CORE 5.00 Jan 09 2006 12:00:00*76
$GPTXT,01,01,02,LIC 1EBF-BD07-E83D-6BE1-0F7A*50
$GPRMC,,V,,,,,,,,,,N*53
$GPVTG,,,,,,,,,N*30
2. but after set-nmea.py on and enable-raw.py are used, there are no any data
goes to /dev/ttySAC1 at all.
I cannot understand what exactly i am doing wrong.
Would appreciate your help.
root at om-gta02:~/ubx# ./set-nmea.py off
callback ['CFG-PRT', [{}, {'Baudrate': 9600, 'PortID': 1, 'Flags': 0, 'Mode': 526544, 'In_proto_mask': 7, 'Out_proto_mask': 3}]]
callback ['ACK-ACK', [{'MsgID': 0, 'ClsID': 6}]]
root at om-gta02:~/ubx# ./enable-raw.py
Thanks
On Mar 2, 2013, at 8:13 PM, Timo Juhani Lindfors <timo.lindfors at iki.fi> wrote:
> mrt <oddpost at ya.ru> writes:
>> I was trying to find some information about how to get raw data from the gps
>> module? Do I need to use modified firmware, is it available for
>> download?
> No, you just change one byte in the RAM of the GPS chip using a UBX
> protocol command.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS
