[FOSS-GPS] impressed
Tomoji TAKASU
ttaka at yk.rim.or.jp
Tue Mar 19 00:37:39 PDT 2013
Dear oddpost
> When working with Type 18 and Type 19 messages, should Input
> Stream be set as (2) Base Station or (3) Correction?
Please set (2).
> Options for positioning mode should be set as "Kinematic"?
If moving, set "Kinematic".
If stationary, set either "Kinematic" or "Static".
Tomoji TAKASU
Sent: Tuesday, March 19, 2013 4:22 PM
To: "Open Source GPS-related discussion and support"
<foss-gps at lists.osgeo.org>
Subject: Re: [FOSS-GPS] impressed
> Hello,
> I am trying to figure out rtknavi settings. I am using openmoko freerunner
> and would like to get relatively precise positioning (using RTK).
> I have access to ntrip, providing Type 1 (differential GPS corrections),
> Type 3 (BS parameters), Type 18 (uncorrected carrier phase measurements),
> Type 19 (virtual distance uncorrected observations).
> When working with Type 18 and Type 19 messages, should Input Stream be set
> The idea is to get the following simple architecture:
> freerunner --> rtknavi <---- ntrip
> Thanks a lot for your help
> On Mar 16, 2013, at 11:46 PM, Artyom G <gnsssdr at gmail.com> wrote:
>> Dear all,
>> I also want to thank developers of RTKlib.
>> During last month one the students under my control tested nvs08c-csm
>> with
>> RTKlib. At first we tried to get our coordinates relative to RTCM base
>> station. During 3 days the difference in fix-position coordinates didn't
>> exceed 1cm (on each coordinate). Distance between RTCM station and our
>> antenna was about 3 km. Then we determined coordinates between RTCM
>> station
>> and second reciever. And at the end we determined coordinates between two
>> nvs08c-csm receivers (baseline about 8m).
>> We also checked manually baseline distance between two nvs08c-csm
>> receivers
>> by subtracting coordinates of the first nvs08c-csm receiver (that were
>> got
>> relative to RTCM station) from the coordinates of the second nvc08c-csm
>> receiver (that were also got relative to RTCM station). The result was
>> the
>> same as RTKlib outputed.
>> I also appreciated strongly the posibility to stream data from receiver
>> through "strsvr". It was very comfortable to work with receivers output
>> in
>> parallel with the student.
>> Thanks a lot for RTKlib.
>> On Sat, Mar 16, 2013 at 1:40 PM, Michele Bavaro
>> <mic.bavaro at yahoo.co.uk>wrote:
>>> Great, thank you!
>>> Too many times we hear the opposite.
>>> I am glad that - for once - someone has been willing to share his good
>>> results with RTKLIB combined with low cost receivers.
>>> To cool down you enthusiasm a bit, I anticipate that you should not
>>> expect
>>> much difference between a LEA-4T and a NV08C-CSM. Carrier phase noise is
>>> similar and despite tracking Glonass, that is still hardly usable by
>>> RTKLIB
>>> since it is affected by the well-known biases any Glonass receiver RF
>>> receive path is subject to. And RTKLIB "auto-calibration" feature is
>>> still
>>> not implemented.
>>> If I am allowed, I am under the impression that Tomoji's development
>>> road-map is adding more and more features to RTKLIB so that now
>>> resembles
>>> very much a professional product rather than an open-source
>>> *one-man*effort. Surely having multiple frequencies, multiple
>>> constellations, super
>>> standalone post-processing (PPP), and beautifully coloured GUIs is great
>>> and we are always grateful to him for that. But I wonder how many users
>>> desire to have a robust and very lean single frequency GPS RTK
>>> algortihm.
>>> One that can run headless on Android perhaps, or even on a STM32F4 bare
>>> metal. One that can fill the gap with the most common quirks of low-cost
>>> receivers (e.g. random phase slips) and use some sort of pre-processing
>>> RAIM to indentify and exclude outliers. One that can be integrated in
>>> robotic automatic guidance projects.
>>> Back to receivers, the only real difference between NV08C-CSM and LEA-4T
>>> is that the latter is gone out of production several years ago, and
>>> uBlox
>>> has not replaced it with an equally performing module. 5T and 6T in fact
>>> can only measure at 10Hz under certain conditions and they are not
>>> certified to do that anyway.
>>> So if you need a module to build a commercial product you only have
>>> three
>>> choices right now: NVS NV08C-CSM, ublox 6T/P, and Skytraq S1315F-RAW.
>>> Of the three, only the first has to my knowledge a clear development and
>>> upgrade path. There are rumors that the new revision of NV08C -to come
>>> out
>>> later this year- will fully support Galileo and, as most of us know,
>>> Galileo Signal In Space specifications guarantee interoperability with
>>> GPS
>>> by design. Thus, as soon as there will be a sensible number of Galileo
>>> birds in the sky, dual constellation low-cost RTK will become easily
>>> useable by all of us. Not to mention dual frequency of course, as L5 and
>>> E5a bands overlap.
>>> Congratulations again and keep it up,
>>> Michele
>>> On 16/03/2013 09:04, napoleon wrote:
>>> Hello,
>>> My setup is:
>>> Rover:40db tallysman antenna, lea-4t receiver
>>> Base: leica 1202gg antenna ntrip caster connection,rtcm 3 data.
>>> baseline 6.68 m
>>> base -kinimatic solution
>>> I searched for the lea-4t configuration, i set it up, i pressed
>>> ''start''and
>>> i had first fix after 1.5 minute and stable fix after 7 minutes....(less
>>> than 2.5cm)-MY FIRST TRY
>>> Looks like a joke.
>>> I am totally impressed.
>>> I am planning a new config with tallysman gnss antenna and nvs-08 and i
>>> am
>>> afraid to imagine the result.
>>> I will also test vrs and max solutions from the base network (i guess i
>>> can
>>> feed max solution through rtcm 3 to rtklib)
>>> Anyway i have to say again that i am impressed and to thank you ttakasu
>>> and
>>> team.
>>> View this message in context:
>>> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/impressed-tp7572660.html
>>> Sent from the Open Source GPS-related discussion and support mailing
>>> list archive at Nabble.com.
>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
>>> subscription
>>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
>>> subscription
>> subscription
> subscription
More information about the FOSS-GPS
