[FOSS-GPS] RTKLib processing power
weber de souza calixto webersouzacalixto at gmail.com
Tue Oct 1 12:32:50 PDT 2013
Josh,
I'm back on this project.
A question: Did you have problems to compile RTKLib to A9 processor?
In the following weeks I will to compile it, I'm just waiting my dev board
to arrive (
http://br.embeddeddeveloper.com/tools/2654/Newark-element14/MCIMX6Q-SL.htm)
Weber
2013/8/22 weber de souza calixto <webersouzacalixto at gmail.com>
> Hi,
> Josh thanks for sharing your experience. Sure it is helping me a lot to
> choose the processing platform. Right now I`m inclined to choose a
> quad-core 1.2 Ghz A9 to start testing.
> Danny, to use raspberry or beaglebone is dependant on your needs. In my
> case I cant wait RTKLib to compute and then shoot the picture. Airplanes
> can`t hover :)
> Weber
> 2013/8/22 Danny Miller <dannym at austin.rr.com>
>>  What about Raspberry Pi and Beaglebone Black?
>> Danny
>> On 8/21/2013 7:42 PM, Josh Leighton wrote:
>> While I can't speak very scientifically, I can report on our experiences
>> running rtklib on gumstix embedded linux computers.  Previous we used a
>> Gumstix Overo with an ARM cortex-A8 (single core) at 800MHz I believe.  We
>> couldn't reliably do more than 1Hz RTK alongside the other processes we
>> were running.  If I recall correctly, rtknavi was using ~15% cpu at 1Hz.
>>  Now with a Duovero (dual core, arm cortex-A9 at 1GHz) we have no
>> problem running RTK at 5Hz.  Cpu usage is still around 15%.
>>  Hope that's of some help to you.
>>  -Josh
>> On Wed, Aug 21, 2013 at 8:19 PM, Weber <webersouzacalixto at gmail.com>wrote:
>>> Hi all,
>>> Question: How much processing power to get real time RTK corrections
>>> from RTKLib?
>>> I'm thinking of using uBlox LEA-6T-0 (5 Hz RAW update) on both
>>> basestation and rover (a UAV), with RTKNAVI or an adaptation running on the
>>> rover so I need to choose a onboard computer capable.
>>> Thanks,
>>> Weber
>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
>>> subscription
>>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
>> subscription
> Weber de Souza Calixto
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20131001/d03d3fca/attachment.html>
More information about the FOSS-GPS mailing list
