[FOSS-GPS] RTKLIB raw data
Tomoji TAKASU
ttaka at yk.rim.or.jp
Sat Oct 26 10:56:48 PDT 2013
Dear knightd
> We have the GPS connected to an arm. Within the arm we have to have a
> function called by our main (), or an external interruption, which go
> directly read the output of the GPS (this output on my gps can be RS-232,
> spi or pps) and then can you call the function input_raw the library here
> (file) rcvraw.c right?
You mean how to read data from the external
device in your main()? If so, it basically depends
on your device and the OS.
Under Windows or Linux, RTKLIB provides general
stream APIs for such devices. See stream.c.
regards,
Tomoji TAKASU
Sent: Sunday, October 27, 2013 2:35 AM
To: <foss-gps at lists.osgeo.org>
Subject: Re: [FOSS-GPS] RTKLIB raw data
> Dear ttaka,
> What I mean is the following:
> Or am I to understand it wrong way to interpret the data from the GPS?
> greetings
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLIB-raw-data-tp7572740p7572748.html
> Sent from the Open Source GPS-related discussion and support mailing list
> archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
> ‚±‚̃ƒbƒZ[ƒW‚ɃEƒCƒ‹ƒX‚ÍŒŸo‚³‚ê‚Ü‚¹‚ñ‚Å‚µ‚½B
> AVG ‚É‚æ‚Á‚ă`ƒFƒbƒN‚³‚ê‚Ü‚µ‚½ - www.avg.com
> ƒo[ƒWƒ‡ƒ“F 2014.0.4158 / ƒEƒCƒ‹ƒXƒf[ƒ^ƒx[ƒXF3614/6776 - ƒŠƒŠ[ƒX“úF2013/10/23
More information about the FOSS-GPS
