[FOSS-GPS] Using RTKLib with Novatel OEM device as base
jtwork
taflan.work at gmail.com
Thu Aug 21 10:14:27 PDT 2014
Hello, I'm trying to set up a system with RTKLib consisting of a uBlox 6T
receiver and another device that outputs Novatel OEM messages. I was hoping
to use the 6T as my rover, and then have the OEM output be used as my base
station. I attempted to simply turn on all of the RAW messages I see
available in the OEM message list, but I don't get any success with this, as
I only can see the uBlox and it tells me it's operating in "SINGLE" mode.
My question is if someone knows the proper configuration so that I can use
the Novatel OEM format in my system.
Thanks!
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Using-RTKLib-with-Novatel-OEM-device-as-base-tp7572967.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
