[FOSS-GPS] Using RTKLib with Novatel OEM device as base
Anton Strydom
agstrydom at gmail.com
Mon Aug 25 21:16:04 PDT 2014
Hi
With your 6T you need to turn on RXM-RAW and RXM-SFRB else it will not
work. What Novatel device are you using? Is it dual frequency?
What are you using to communicate between the Base an Rover
On Thu, Aug 21, 2014 at 7:14 PM, jtwork <taflan.work at gmail.com> wrote:
> Hello, I'm trying to set up a system with RTKLib consisting of a uBlox 6T
> receiver and another device that outputs Novatel OEM messages. I was
> hoping
> to use the 6T as my rover, and then have the OEM output be used as my base
> station. I attempted to simply turn on all of the RAW messages I see
> available in the OEM message list, but I don't get any success with this,
> as
> I only can see the uBlox and it tells me it's operating in "SINGLE" mode.
> My question is if someone knows the proper configuration so that I can use
> the Novatel OEM format in my system.
> Thanks!
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Using-RTKLib-with-Novatel-OEM-device-as-base-tp7572967.html
> Sent from the Open Source GPS-related discussion and support mailing list
> archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140826/ebe6409f/attachment.html>
More information about the FOSS-GPS
