[FOSS-GPS] Using RTKLib with Novatel OEM device as base
jtwork
taflan.work at gmail.com
Wed Aug 27 11:44:44 PDT 2014
Thanks for your reply.
I'm connecting to both of them over the network actually. I have telnet
into the Novatel and see that it outputs all of the messages I specify
correctly, but I'll try disabling the RTCM and enabling only the OEM
messages listed in the documentation and see if that helps.
The OEMV-3 is listed as a "triple frequency + L-band" receiver.
Just to check, should I be connecting to the Novatel as a "base station" or
as "corrections"? Those two options are a bit confusing to me..
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Using-RTKLib-with-Novatel-OEM-device-as-base-tp7572967p7572972.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
