[FOSS-GPS] Using RTKLib with Novatel OEM device as base
Anton Strydom agstrydom at gmail.com
Wed Aug 27 07:26:32 PDT 2014
Hi there
First of all it sounds like your 6T works and I take it that is connected
to a PC via COM(?). Is the Base connected to the same PC and if so what
port and does the PC see it? Easy way to check is to load Putty,opening the
port that the unit is connected to and seeing what you receiving from the
receiver.
I would not enable RTCM3 on the Novatel receiver and keep it basic to start
off with
Is your Novatel single or dual frequency?
Regards
On Wed, Aug 27, 2014 at 2:25 PM, jtwork <taflan.work at gmail.com> wrote:
> Hello,
> I have turned on both RXM-RAW and RXM-SFRB messages, and using RTKLib I can
> successfully get a SINGLE lock.  So far I can't get my base station to work
> in conjunction to get a real rtk fix.
> I'm using the Novatel OEMV-3.  I found that it outputs RTCM messages, so I
> tried enabling the RTCM3 messages 1002, 1006, 1007, 1008, and 1019, however
> when I try connecting to the Novatel as both a 'base station' and then
> later
> as 'correction', it does not ever find a fix beyond "SINGLE".
> I did previously try enabling the OEMV messages like RAWEPHEM that were
> listed as supported, but that didn't seem to work either.  I have also
> input
> the base station position information in the options.
> Any help with further configuration would be greatly appreciated.  I
> suspect
> that I might just have the wrong messages setup or have something wrong
> with
> my connection settings, but I am really not too sure at the moment...
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Using-RTKLib-with-Novatel-OEM-device-as-base-tp7572967p7572970.html
> Sent from the Open Source GPS-related discussion and support mailing list
> archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140827/cdc0ba5f/attachment.html>
More information about the FOSS-GPS mailing list
