[FOSS-GPS] Using RTKLib with Novatel OEM device as base
agstrydom at gmail.com
Wed Aug 27 20:24:07 PDT 2014
That's correct Base
------Original Message------
Sender: foss-gps-bounces at lists.osgeo.org
To: foss-gps at lists.osgeo.org
ReplyTo: Open Source GPS-related discussion and support
Subject: Re: [FOSS-GPS] Using RTKLib with Novatel OEM device as base
Sent: Aug 27, 2014 8:44 PM
Thanks for your reply.
I'm connecting to both of them over the network actually. I have telnet
into the Novatel and see that it outputs all of the messages I specify
correctly, but I'll try disabling the RTCM and enabling only the OEM
messages listed in the documentation and see if that helps.
The OEMV-3 is listed as a "triple frequency + L-band" receiver.
Just to check, should I be connecting to the Novatel as a "base station" or
as "corrections"? Those two options are a bit confusing to me..
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Using-RTKLib-with-Novatel-OEM-device-as-base-tp7572967p7572972.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
Sent via my BlackBerry from Vodacom - let your email find you!
More information about the FOSS-GPS
