[FOSS-GPS] Using RTKLib with Novatel OEM device as base
Anton Strydom
agstrydom at gmail.com
Thu Aug 28 07:24:54 PDT 2014
Hi there
Things do not make sense to me.
Lets go to basics before we carry on, connect the Novatel receiver to a COM
port and make sure you are getting the proper messages from it. Run RTKNAVI
and look at what you are getting from the receiver. to do this open RTKNAVI
and click on the box circled in red as per the attachment
Select Rover or base and have a look if you getting the proper messages.
Once you have figured this out everything should work
Regards
On Thu, Aug 28, 2014 at 3:34 PM, jtwork <taflan.work at gmail.com> wrote:
> I actually had previously enabled the ASCII OEM messages, so I thought by
> enabling the binary ones, namely RANGEB, RANGECMPB, RAWEPHEMB, IONUTCB, and
> RAWWAASFRAMEB that I would solve the issue.
> Unfortunately, even with this change I'm not seeing any output from RTKLib,
> whether it's with the Novatel as a base station or just connection it in
> single mode as the rover. I don't even see it as reading any satellite
> info
> in the small graphs.
> I'm uncertain as to the problem since when I telnet to the Novatel, I can
> plainly see that it is outputting all of the data perfectly, in the odd way
> that the Novatel outputs binary at least.
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Using-RTKLib-with-Novatel-OEM-device-as-base-tp7572967p7572974.html
> Sent from the Open Source GPS-related discussion and support mailing list
> archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140828/5f8a9231/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140828/5f8a9231/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140828/5f8a9231/attachment-0003.png>
More information about the FOSS-GPS
