[FOSS-GPS] Using RTKLib with Novatel OEM device as base
jtwork
taflan.work at gmail.com
Thu Aug 28 08:00:19 PDT 2014
I think I may have discovered the issue... I'm reading the 'log' information,
which is this odd formatted binary info. It looks like in order to actually
get the raw binary I have to connect via the serial like you suggested,
however that is impossible in my case since that port is in active use by
someone else.. plus I don't actually have physical access to it!
So, I guess unless there's some way to enable raw output over the network
connection, or I write some weird parser, I won't be using this method...
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Using-RTKLib-with-Novatel-OEM-device-as-base-tp7572967p7572977.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
