[FOSS-GPS] Using RTKLib with Novatel OEM device as base
Anton Strydom
agstrydom at gmail.com
Thu Aug 28 09:41:54 PDT 2014
Hi there
On certain Novatel receivers you can get the proper data via TCP I am just
not sure which ones, The ones I use only have 3 com ports rs232 and
bluetooth and I get good data from them
Regards
On Thu, Aug 28, 2014 at 5:00 PM, jtwork <taflan.work at gmail.com> wrote:
> I think I may have discovered the issue... I'm reading the 'log'
> information,
> which is this odd formatted binary info. It looks like in order to
> actually
> get the raw binary I have to connect via the serial like you suggested,
> however that is impossible in my case since that port is in active use by
> someone else.. plus I don't actually have physical access to it!
> So, I guess unless there's some way to enable raw output over the network
> connection, or I write some weird parser, I won't be using this method...
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Using-RTKLib-with-Novatel-OEM-device-as-base-tp7572967p7572977.html
> Sent from the Open Source GPS-related discussion and support mailing list
> archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140828/ec640ca4/attachment.html>
More information about the FOSS-GPS
