[FOSS-GPS] RTKPLOT - Difference in output
mazahirp
mazahir.poonawalla at gmail.com
Mon Feb 24 04:10:19 PST 2014
Hi All,
I recently did a RTK test using RTKLIB (RTKNAVI) and simultaneously I was
a). logging the data b). logging lat/long/height and c). logging the
baseline.
Now using RTKCONV & RTKPOST I again converted the data and used RTKPLOT to
view the results. What I see that when I plot the baseline values (E/N/U) in
excel and compare it with the plot in RTKPLOT, there is major difference in
the graph and also the max/min values. What could be the reason? In RTKPOST,
I used exactly the same settings as RTKNAVI.
Thank you.
Cheers,
Max
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKPLOT-Difference-in-output-tp7572823.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
