[FOSS-GPS] RTKPLOT - Difference in output
mazahirp
mazahir.poonawalla at gmail.com
Thu Feb 27 01:23:22 PST 2014
Hi Julio,
Thanks. Yes I am attaching the necessary files.
So my setup is such that I used one as a base and one as rover, both kept
approx 14 - 15 meters apart. Both are as input to RTKNAVI via serial and I
am logging data, baseline and lat/long/altitude in three different files
respectively.
I have attached 2 zip folders containing logs of 2 different config
options. Both are as "Moving Base", and hence no base position is required.
One folder is containing data for "continuous" ambiguity resolution setting
and the other for "fix and hold". Both capture only L1. Rest of the
settings are default.
Using the baseline file, I plotted the E/N/U values in excel. Using the
base and rover log files, I converted to RINEX using RTKCONV and then did a
RTKPOST followed by plotting using RTKPLOT. There is a difference between
baseline position plot in excel and RTKPLOT.
I am sharing all my files. I hope all this will help you to figure out what
is going on, what is right or wrong and what could be rectified and how
should it be taken forward.
Do let me know in case you need anything else.
Thank you once again.
Cheers,
Max
MovingBase_Fix&Hold.zip<https://docs.google.com/file/d/0B_f9SpI3EgsuUGJ2TlJWN1h3dWc/edit?usp=drive_web>
MovingBase_Continuous.zip<https://docs.google.com/file/d/0B_f9SpI3EgsuQnc1aHR3allpdms/edit?usp=drive_web>
On Wed, Feb 26, 2014 at 5:19 PM, julio menezes [via Open Source GPS-related
discussion and support] <ml-node+s1099874n7572825h9 at n2.nabble.com> wrote:
> Hi Max,
> Could you share your config, your raw logged data, rtkpost solutions and
> base station position ?
> Please, if possible, describe your field test.
> Although I do not use Excel or Windows, I will try to help.
> regards
> julio menezes
> Em Quarta-feira, 26 de Fevereiro de 2014 2:40, mazahirp <[hidden email]<http://user/SendEmail.jtp?type=node&node=7572825&i=0>>
> escreveu:
> Hi All,
> Any help on this one? How could I study this better?
> Thanks once again.
> Cheers,
> Max
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKPLOT-Difference-in-output-tp7572823p7572824.html
> Sent from the Open Source GPS-related discussion and support mailing list
> archive at Nabble.com.
> This message is sent to you from [hidden email]<http://user/SendEmail.jtp?type=node&node=7572825&i=1>mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
> This message is sent to you from [hidden email]<http://user/SendEmail.jtp?type=node&node=7572825&i=2>mailing list.
> subscription
> If you reply to this email, your message will be added to the discussion
> below:
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKPLOT-Difference-in-output-tp7572823p7572825.html
> To unsubscribe from RTKPLOT - Difference in output, click here<http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=7572823&code=bWF6YWhpci5wb29uYXdhbGxhQGdtYWlsLmNvbXw3NTcyODIzfDU2ODAwNTgyMw==>
> NAML<http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKPLOT-Difference-in-output-tp7572823p7572826.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140227/fe304544/attachment.html>
More information about the FOSS-GPS
