[FOSS-GPS] RTKPLOT - Difference in output
Mazahir Poonawalla
mazahir.poonawalla at gmail.com
Fri Feb 28 03:03:55 PST 2014
Hi Julio,
I have attached the two conf files. Both are capturing only L1.
Do let me know incase you need any help.
Thank you once again.
Cheers,
Max
On Thu, Feb 27, 2014 at 5:38 PM, julio menezes <yjmenezes at yahoo.com.br>wrote:
> Hi Max,
> Please, send me your rtknavi_rtk.conf ( configuration file )
> check your settings, the solution header shows L1+L2, must be L1 only:
> % pos mode : moving-base
> % freqs : L1+L2
> take a look 2.4.2 manual page 39.
> ʺBaseline Length Constraintʺ enabled
> pre‐determined baseline length
> I will look your files this weekend.
> []s
> julio menezes
> Em Quinta-feira, 27 de Fevereiro de 2014 6:23, mazahirp <
> mazahir.poonawalla at gmail.com> escreveu:
> Hi Julio,
> Thanks. Yes I am attaching the necessary files.
> So my setup is such that I used one as a base and one as rover, both kept
> approx 14 - 15 meters apart. Both are as input to RTKNAVI via serial and I
> am logging data, baseline and lat/long/altitude in three different files
> respectively.
> I have attached 2 zip folders containing logs of 2 different config
> options. Both are as "Moving Base", and hence no base position is required.
> One folder is containing data for "continuous" ambiguity resolution setting
> and the other for "fix and hold". Both capture only L1. Rest of the
> settings are default.
> Using the baseline file, I plotted the E/N/U values in excel. Using the
> base and rover log files, I converted to RINEX using RTKCONV and then did a
> RTKPOST followed by plotting using RTKPLOT. There is a difference between
> baseline position plot in excel and RTKPLOT.
> I am sharing all my files. I hope all this will help you to figure out
> what is going on, what is right or wrong and what could be rectified and
> how should it be taken forward.
> Do let me know in case you need anything else.
> Cheers,
> Max
> MovingBase_Fix&Hold.zip<https://docs.google.com/file/d/0B_f9SpI3EgsuUGJ2TlJWN1h3dWc/edit?usp=drive_web>
> MovingBase_Continuous.zip<https://docs.google.com/file/d/0B_f9SpI3EgsuQnc1aHR3allpdms/edit?usp=drive_web>
> On Wed, Feb 26, 2014 at 5:19 PM, julio menezes [via Open Source
> GPS-related discussion and support] <[hidden email]> wrote:
> Hi Max,
> Could you share your config, your raw logged data, rtkpost solutions and
> base station position ?
> Please, if possible, describe your field test.
> Although I do not use Excel or Windows, I will try to help.
> regards
> julio menezes
> Em Quarta-feira, 26 de Fevereiro de 2014 2:40, mazahirp <[hidden email]<http://user/SendEmail.jtp?type=node&node=7572825&i=0>>
> escreveu:
> Hi All,
> Any help on this one? How could I study this better?
> Thanks once again.
> Cheers,
> Max
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKPLOT-Difference-in-output-tp7572823p7572824.html
> Sent from the Open Source GPS-related discussion and support mailing list
> archive at Nabble.com.
> This message is sent to you from [hidden email]<http://user/SendEmail.jtp?type=node&node=7572825&i=1>mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
> This message is sent to you from [hidden email]<http://user/SendEmail.jtp?type=node&node=7572825&i=2>mailing list.
> subscription
> If you reply to this email, your message will be added to the discussion
> below:
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKPLOT-Difference-in-output-tp7572823p7572825.html
> To unsubscribe from RTKPLOT - Difference in output, click here.
> NAML<http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: RTKPLOT - Difference in output<http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKPLOT-Difference-in-output-tp7572823p7572826.html>
> archive<http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/>at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> subscription
> subscription
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140228/08604c6a/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140228/08604c6a/attachment-0002.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140228/08604c6a/attachment-0003.obj>
More information about the FOSS-GPS
