[FOSS-GPS] Baseline
agstrydom at gmail.com
Mon Jan 27 04:24:17 PST 2014
Hi Max
The base line is simply the distance between the base and rover
Especially if you use L1, the longer the base line the less accurate the solution
Normally you would be restricted to about 10 km depending on how you communicate between the rover and base
Trust the above answers your question
Anton
------Original Message------
Sender: foss-gps-bounces at lists.osgeo.org
To: foss-gps at lists.osgeo.org
ReplyTo: Open Source GPS-related discussion and support
Subject: [FOSS-GPS] Baseline
Sent: Jan 27, 2014 2:19 PM
Hi All,
What is baseline and why is it necessary?
Please answer.
Cheers,
Max
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Baseline-tp7572808.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
Sent via my BlackBerry from Vodacom - let your email find you!
More information about the FOSS-GPS
