[FOSS-GPS] Baseline
Mazahir Poonawalla mazahir.poonawalla at gmail.com
Mon Jan 27 05:15:56 PST 2014
Thank you for the answer.
Then why is it said that RTK baseline needs to be initialized? Can't we
just start capturing raw at both the base and rover and calculate the
position?
Cheers,
Max
On Jan 27, 2014 5:57 PM, <agstrydom at gmail.com> wrote:
> Hi Max
> The base line is simply the distance between the base and rover
> Especially if you use L1, the longer the base line the less accurate the
> solution
> Normally you would be restricted to about 10 km depending on how you
> communicate between the rover and base
> Trust the above answers your question
> Anton
> ------Original Message------
> From: mazahirp
> Sender: foss-gps-bounces at lists.osgeo.org
> To: foss-gps at lists.osgeo.org
> ReplyTo: Open Source GPS-related discussion and support
> Subject: [FOSS-GPS] Baseline
> Sent: Jan 27, 2014 2:19 PM
> Hi All,
> What is baseline and why is it necessary?
> Please answer.
> Cheers,
> Max
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Baseline-tp7572808.html
> Sent from the Open Source GPS-related discussion and support mailing list
> archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
> Sent via my BlackBerry from Vodacom - let your email find you!
> subscription
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140127/40c9965a/attachment.html>
More information about the FOSS-GPS mailing list
