[FOSS-GPS] (Basic) Minicom does not show correct Output
JOHN LYNCH john.lynch at willyn.com
Thu Jul 10 07:21:09 PDT 2014
I am not familiar with the minicom, but I also found I had to patch some of the RTK serial port handling on Mac os x (which uses standard Unix serial port handling) to get port writes to work correctly.  Up until then, the ublox would just send the default format.  Check to see if the port writes are actually working correctly to see if the ublox commands are getting through.
This was a few months ago, but I would be happy to resurrect my work and send along the patch if you are up for rebuilding RTK utilities with it.  As I recall, it was minimally invasive to the existing code (1 or 2 lines to set some additional flag bits).
Let me know.
JohnL
On Jul 10, 2014, at 9:59 AM, MichaelFerrero <dav.mercenary at gmail.com> wrote:
> Yes I turned the Hardware Control off but the problem persists.
> I also change the baud rate of minicom and also changed it for my consolve
> using stty -F /dev/ttyACM0 38400.
> I tried the same with baud rate  but I get the same problem.
> I dont know what to do now.
> View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Basic-Minicom-does-not-show-correct-Output-tp7572953p7572955.html
> Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
