[FOSS-GPS] Min Ratio to Fix Ambiguity
mazahirp mazahir.poonawalla at gmail.com
Mon Mar 10 22:14:05 PDT 2014
Hi All,
Can anyone explain what is "Min Ratio to Fix Ambiguity" in RTKNAVI/RTKPOST
options->settings2. What does it do?
Default = 3. When I change to 2 or 1, I get more fix values. Why is it so?
I cannot understand from the manual.
Thank you.
Cheers,
Max
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Min-Ratio-to-Fix-Ambiguity-tp7572829.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS mailing list
