[FOSS-GPS] Good antenna
mazahirp
mazahir.poonawalla at gmail.com
Mon Mar 10 22:52:50 PDT 2014
Hi All,
Can anyone help me to buy a good antenna which can give me accurate results.
I am using u-blox 6T as receiver and RTKLIB.
Currently I am using GILSON GPS active antenna on both the receivers (base
and rover). I am not an expert into antennas so I wanted to know if this
antenna is good enough? If not, which one should I go for. My budget is
around $100.
Thanks for the help.
Cheers,
Max
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Good-antenna-tp7572830.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
