[FOSS-GPS] Good antenna (Choke ring)
Christopher S.
siriusc23 at gmail.com
Thu Mar 13 06:41:30 PDT 2014
One could use a good quality active patch antenna and build a *choke
ring*for it, that would improve its performance substantially.
A choke ring is a series of concentric circle traps of the correct length
to attenuate signals that are likely to be multi-path.
The dimensions are online.
Also, most people must know this already but those patch antennas all need
to be on a ground plane to work properly.
Chris
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140313/af35edb6/attachment.html>
More information about the FOSS-GPS
