[FOSS-GPS] BINR to RTCM
James Fielding james.fielding at precisiondecisions.co.uk
Fri May 2 03:23:17 PDT 2014
Thanks for that - I'm going to assume if the other Binary formats translate to RTCM 3.x then there is no reason why BINR won't as it appears in the conversion list.
James Fielding
Precision Decisions, The Old Station Works, Station Lane, Shipton-by-Beningbrough, York, YO30 1BS
T: +44(0)1347 844 132
-----Original Message-----
From: foss-gps-bounces at lists.osgeo.org [mailto:foss-gps-bounces at lists.osgeo.org] On Behalf Of agstrydom at gmail.com
Sent: 01 May 2014 16:34
To: Open Source GPS-related discussion and support
Subject: Re: [FOSS-GPS] BINR to RTCM
Hi James
I have tested it with an number of receivers, hemisphere a325, novatel and u-blocks and it works perfectly well
Have however not tested with BINR as yet
Regards
Sent via my BlackBerry from Vodacom - let your email find you!
From: James Fielding <james.fielding at precisiondecisions.co.uk>
Sender: foss-gps-bounces at lists.osgeo.org
Date: Thu, 1 May 2014 11:54:39
To: foss-gps at lists.osgeo.org<foss-gps at lists.osgeo.org>
Reply-To: Open Source GPS-related discussion and support
Subject: [FOSS-GPS] BINR to RTCM
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
This email, its contents and any files transmitted with it are private and confidential.
Access by any other party is unauthorised without the express written permission of the sender. If you have received this email in error you may not copy or use the contents, attachments or information in any way. Please destroy it and contact the sender via email return. This email has been prepared using information believed by the author to be reliable and accurate but Precision Decisions make no warranty as to accuracy or completeness.
In particular Precision Decisions does not accept responsibility for changes made to this email after it was sent. Any opinions expressed in this document are those of the author and do not necessarily reflect the opinions of Precision Decisions or its affiliates.
The contents of any attachment to this email may contain software viruses which could damage your own computer system. While Precision Decisions has taken every reasonable precaution to minimise this risk we cannot accept liability for any damage which you sustain as a result of software viruses. You should carry out your own virus checks before opening the attachment.
Precision Decisions Limited is a company registered in England and Wales.
Registered Company No: 05717670
Registered Office:
Station Lane
Shipton by Beningbrough
York
YO30 1BS
More information about the FOSS-GPS mailing list
