[FOSS-GPS] u-blox EVK-6PPP and EVK-6T, Can its use together?
nomtot
niponsommai at gmail.com
Tue Nov 18 12:48:58 PST 2014
Hi all,
I tested positioning mode RTK with RTKNAVI ver2.4.1, by used u-blox EVK-6PPP
is the base station and u-blox EVK-6T is the rover, but there much variance
points with RTKPLOT.
I want to know, Can Its use together in solution RTK?
Thank for you help,
nomtot.
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/u-blox-EVK-6PPP-and-EVK-6T-Can-its-use-together-tp7573081.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
