[FOSS-GPS] Ephemeris storage, how to purge it in RTKLIB and RTKnavi
David Kelley
DavidKelley at ITSware.net
Mon Nov 17 09:35:52 PST 2014
Again, many thanks to Dan for his explanation.
Now that I see the INI file in use (and know to remove it from memory
with a restart), much becomes clear when controlling different filter
types. But one thing remains odd to me, the intended use of the
*config file in all this.
If seems to overlap with the *.ini file in many ways and saves very
similar information and settings strings., to wit, all the file paths
seem to be saved in both places.
Clearly the *config file is intended to have all the navigation filter
settings, but that too is found in the *.in file (ie mode etc. )
If there any item that is in fact set on one and not the other? When
does one use each? I do not see anything in the manual about this.
On 11/15/2014 8:22 AM, David Kelley wrote:
> Thanks Dan
> When I cut that part of the *.ini file off, AND restart RTKnavi it
> then loses all the data. Yeah!
> The cold restart is needed as it seems to keep the past ephemeris in
> memory as well, and it will not re-read the *.ini file until that
> moment in time.
> - cut - - cut -
Regards,
David Kelley
ITS Programs Manager
SubCarrier Systems Corp. (SCSC)
1833 East Foothill Blvd. Glendora, CA USA 91741
626-485-7528 (Cell) 888-950-8747 (Main)
626-513-7715 (Office) 888-613-0757 (Fax)
<DavidKelley at ITSware.net>
More information about the FOSS-GPS
