[FOSS-GPS] A Simple summary for ublox EVK-6T setting for RTKlib(single Mode)
jeremy.bouathong
bouathbouath at gmail.com
Fri Oct 10 05:16:09 PDT 2014
Did you succeed the kinematic or moving baseline mode? I'm currently working
on the evk 6t too. But i can't get any FIX solution. I have 2 EVK 6T. I
configured the both receivers like you did in the message above. I have like
10 meters between the receivers. I don't understand why i can't even have a
FLOAT solution.
Regards,
Jeremy
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/QnA-ublox-EVK-6T-setting-for-RTKlib-video-capture-included-tp7146506p7573030.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
