[FOSS-GPS] A Simple summary for ublox EVK-6T setting for RTKlib(single Mode)
bjorn.spockeli
bjorn.spockeli at gmail.com
Fri Oct 31 06:05:01 PDT 2014
Hi Jeremy,
Im also using 2 EKV-6T's in moving baseline mode and im able get a float
solution( have not been able to get fix) with the following configuration
file. rtkrcv.conf
<http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/file/n7573065/rtkrcv.conf>
However im using the RTKLIB CUI AP's in Linux and not the WIndows GUI, but i
think you should be able to use the same .conf file regardless of platform.
You may have to modify it as sending the base data with str2str (using it a
tcpserver) to rtkrcv (tcpclient).
Please post your configuration file so we can compare them :)
Best Regards
Bjørn
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/QnA-ublox-EVK-6T-setting-for-RTKlib-video-capture-included-tp7146506p7573065.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
