[FOSS-GPS] RTKLIB FIX solution - Hold problem
jeremy.bouathong
bouathbouath at gmail.com
Mon Oct 13 04:38:32 PDT 2014
i'l currently working on the Kinematic mode and the Moving Baseline mode on
RTKLIB. I succeeded to get FIX solutions for this two modes. The problem is
that i can get a FIX solution when the rover is static. When i move the
rover, the solution is FLOAT and RTKLIB searchs for an other Integer
solution. In Options i configured the Fix and Hold solution, so I don't
understand why i can't hold the solution i first found. I changed the bps on
the COM options to 115000 bps to get more datas but it doesn't change
anything. Can it be a hardware problem? I'm using a very old computer, with
a low processor...
Regards
Jérémy
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLIB-FIX-solution-Hold-problem-tp7573031.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
