[FOSS-GPS] RTKLIB FIX solution - Hold problem
Forrest Voight
forrest.voight at gmail.com
Mon Oct 13 06:51:43 PDT 2014
What receiver are you using? I've noticed that some don't maintain
carrier lock when moved at all, making only static positioning
possible.
On Mon, Oct 13, 2014 at 7:38 AM, jeremy.bouathong
<bouathbouath at gmail.com> wrote:
> Hi,
> i'l currently working on the Kinematic mode and the Moving Baseline mode on
> RTKLIB. I succeeded to get FIX solutions for this two modes. The problem is
> that i can get a FIX solution when the rover is static. When i move the
> rover, the solution is FLOAT and RTKLIB searchs for an other Integer
> solution. In Options i configured the Fix and Hold solution, so I don't
> understand why i can't hold the solution i first found. I changed the bps on
> the COM options to 115000 bps to get more datas but it doesn't change
> anything. Can it be a hardware problem? I'm using a very old computer, with
> a low processor...
> Regards
> Jérémy
> View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLIB-FIX-solution-Hold-problem-tp7573031.html
> Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS
