[FOSS-GPS] RTKLIB FIX solution - Hold problem
jeremy.bouathong
bouathbouath at gmail.com
Mon Oct 13 07:44:56 PDT 2014
I'm using two EVK 6t (evaluation kit for LEA 6T). Maybe with some specific
configuration it'll be possible to hold the Integer Ambiguity : like the min
Fix/ Elevation to hold ambiguity (settings 2). But i don't get what Min Fix
means...
Regards,
Jeremy
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLIB-FIX-solution-Hold-problem-tp7573031p7573033.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
