[FOSS-GPS] RTKLIB FIX solution - Hold problem
jeremy.bouathong
bouathbouath at gmail.com
Mon Oct 13 23:56:30 PDT 2014
Thanks for your answer David,
I don't mind the length. You explained everything well. I hope it'll help me
to find the issue. Do you think that using a cheap receiver but high grade
antenna could be a solution?
Regards,
Jeremy
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLIB-FIX-solution-Hold-problem-tp7573031p7573036.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
