[FOSS-GPS] RTKLIB FIX solution - Hold problem
David Kelley
DavidKelley at ITSware.net
Tue Oct 14 07:43:26 PDT 2014
Well it never hurts. Does your deploymnent use case invlove moving and re estblishing your base point? If it does not you may be able to calibrate out any effect you see. I have seen people stand about near thier own base station and not be aware that they themselves have become thier own soure of multipath from this, so stand back 10 meters of so if you will be close to the site. On the ublox 6t units we use I selected an Antcom unit for about 450 us dollars that works very well, but I do not have model number at hand here.
Regards, David Kelley, from a tablet device, please excuse my spelling
-----Original Message-----
From: "jeremy.bouathong" <bouathbouath at gmail.com>
To: foss-gps at lists.osgeo.org
Sent: Mon, 13 Oct 2014 11:56 PM
Subject: Re: [FOSS-GPS] RTKLIB FIX solution - Hold problem
Thanks for your answer David,
I don't mind the length. You explained everything well. I hope it'll help me
to find the issue. Do you think that using a cheap receiver but high grade
antenna could be a solution?
Regards,
Jeremy
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLIB-FIX-solution-Hold-problem-tp7573031p7573036.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20141014/84634c16/attachment.html>
More information about the FOSS-GPS
