[FOSS-GPS] RTKLIB FIX solution - Hold problem
jeremy.bouathong bouathbouath at gmail.com
Wed Oct 15 00:36:47 PDT 2014
Hi David,
thanks for your advice. Do you know what is exactly the Minimum Fix Count to
Hold the Ambiguity?
Regards,
Jeremy
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLIB-FIX-solution-Hold-problem-tp7573031p7573038.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS mailing list
