[FOSS-GPS] RTKLIB
julio menezes
yjmenezes at yahoo.com.br
Wed Oct 15 11:04:48 PDT 2014
Hi bjorn.spockeli !
Em qua, 15/10/14, bjorn.spockeli <bjorn.spockeli at gmail.com> escreveu:
Assunto: [FOSS-GPS] RTKLIB
Para: foss-gps at lists.osgeo.org
Data: Quarta-feira, 15 de Outubro de 2014, 13:01
Im trying to run rtkrcv under linux,
but i've run into some problems and it
would be great if anyone of you could point out what im
doing wrong.
My setup is a ublox lea-6t reciever with a ANN-MS-0-005
Antenna connected to
the usbport of my desktop computer (running Linux Mint 17)
with a Prolific
PL2303 USB-RS232 Converter.
The setup works perfectly with RTKNAVI ver.2.4.2 on
windows.
i suppose you set rxm_raw and rxm_sfrb messages as it works under rtknavi.
Please check your configuration file:
# standalone. for NTRIP set type and path. yours are off
inpstr1-type =serial # serial
inpstr2-type =off # off || ntripcli
inpstr3-type =off # off || ntripcli
# ublox baudrate =ttyACM0:57600:8:n:1:off i guess
inpstr1-path =ttyUSB0:57600:8:n:1:off
inpstr2-path =
inpstr3-path =
# here path and permissions
misc-startcmd =./rtkstart.sh
misc-stopcmd =./rtkshut.sh
file-cmdfile1 =../../../data/ubx_raw_1hz.cmd
file-cmdfile2 =../../../data/ubx_raw_1hz.cmd
i hope it helps.
regards,
julio menezes
More information about the FOSS-GPS
