[FOSS-GPS] RTKLIB
julio menezes
yjmenezes at yahoo.com.br
Thu Oct 16 05:16:00 PDT 2014
Hi Bjørn
Em qui, 16/10/14, bjorn.spockeli <bjorn.spockeli at gmail.com> escreveu:
Assunto: Re: [FOSS-GPS] RTKLIB
Para: foss-gps at lists.osgeo.org
Data: Quinta-feira, 16 de Outubro de 2014, 8:09
Hi julio,
it turned out to be a
permission issue with the serialport. After using
chmod 666 /dev/ttyUSB0 everything worked like a
charm. But thanks for the
help :)
regards Bjørn
I am happy you are a GNU/Linux user and you have solved the problem.
Under Debian GNU/Linux i have had this problem before and i solved adding myself as member of "dialout" group ( I remember now) .
Maybe you should try it under Mint. This way you do not have to change /dev/ttyUSBx permission.
[]s
julio menezes
More information about the FOSS-GPS
