[FOSS-GPS] RTKNAVI Data Rate
jeremy.bouathong
bouathbouath at gmail.com
Thu Oct 30 08:27:10 PDT 2014
Hello,
i've been working on RTKLIB for 3 weeks now. I use 2 LEA-6T from U-Blox.
I've used a 1Hz rate so far. I'm now trying to use the device at 5 Hz but
when I start RTKNAVI, it doesn't work as expected. It seems that RTKNAVI
encouter difficulties to get the datas. When I'm at 1 Hz I have no problems.
I tried with different baud rates but it doesn't change anything. If anyone
has a clue, it'd be helpful.
Regards,
Jérémy
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKNAVI-Data-Rate-tp7573058.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
