[FOSS-GPS] RTKNAVI Data Rate
Jared Bench
jared.bench at gmail.com
Thu Oct 30 08:52:02 PDT 2014
Do you have SBAS enabled on the receiver? If so, try disabling it. I've
seen cases where this extra load on the on-chip processor was causing
dropped messages.
Jared
On Thu, Oct 30, 2014 at 11:27 AM, jeremy.bouathong <bouathbouath at gmail.com>
wrote:
> Hello,
> i've been working on RTKLIB for 3 weeks now. I use 2 LEA-6T from U-Blox.
> I've used a 1Hz rate so far. I'm now trying to use the device at 5 Hz but
> when I start RTKNAVI, it doesn't work as expected. It seems that RTKNAVI
> encouter difficulties to get the datas. When I'm at 1 Hz I have no
> problems.
> I tried with different baud rates but it doesn't change anything. If anyone
> has a clue, it'd be helpful.
> Regards,
> Jérémy
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKNAVI-Data-Rate-tp7573058.html
> Sent from the Open Source GPS-related discussion and support mailing list
> archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20141030/3cce7062/attachment.html>
More information about the FOSS-GPS
