[FOSS-GPS] RTKGPS Android
Dan Cook danco at cox.net
Thu Oct 30 09:58:20 PDT 2014
> Setting like this is correct if trimble R8???
You’ll also need to set your R8 to output RT17 if not already set to do so. And since it’s an R8-2 (?), be sure that it is set to output RT17 only, not RT27. Don’t forget to enable streamed Ephemeris too.
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20141030/73361f5d/attachment.html>
More information about the FOSS-GPS mailing list
