[FOSS-GPS] RTKLIB: str2str output rate
bjorn.spockeli
bjorn.spockeli at gmail.com
Fri Oct 31 05:30:41 PDT 2014
Hi Robert,
Here's the str2str command I use to start the stream
./str2str -in serial://ttyACM0:9600#ubx -out tcpsvr://:50021
And here is the configuration file for rtkrcv:
rtkrcv.conf
<http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/file/n7573063/rtkrcv.conf>
Please reply to this post when you get your setup up an running so we can
compare the results!
Best Regards
Bjørn
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLIB-str2str-output-rate-tp7573056p7573063.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
