[FOSS-GPS] Using RTKLib with Novatel OEM device as base
jtwork
taflan.work at gmail.com
Wed Sep 3 08:35:37 PDT 2014
David,
I'm actually not using the RTCM output, but rather the proprietary OEMV
output. The receiver does output RTCM data, but it appears to still be
encapsulated in the OEMV format when doing so. (the specification shows the
same header info as the other messages)
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Using-RTKLib-with-Novatel-OEM-device-as-base-tp7572967p7572986.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
